跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
How do I make a startup USB drive?
I was given a Macbook Pro mid2009 15” with fractured LCD supports near the base. Still works though, I propped up the display on a jury rigged plastic jig. It has Yosemite OS. How do I make a startup USB thumb drive for it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When you hear the startup chime, press and hold the Option key. Holding that key gives you access to Startup Manager. Once the Startup Manager screen appears, release the Option key. The utility will look for any available drives that include bootable content.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, I know about the option key thing. What I'm looking for is a way to create an external boot/startup thumb drive.
完成的
Easy way use this free program https://diskmakerx.com/, from another working mac you can create it, the only thing that you need is a macOS installer that you can search online for it, due that is old may you will have a hard time.
完成的
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 62
