跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Vertical lines on screen without any connector damage
I was replacing a charger port assembly and when i plugged everything back in there were lines on the screen, so bad you couldnt see anything, however i could tell it was still “on” because vibration worked when i would place a wrong finger on touch id. After cleaning the display connectors with alcohol, very lightly with a brush on both screen and phone, the lines dimmed and the phone was usable but with faint white lines. After being quite stuck i unplugged and plugged in again and it was unusable again, really bad lines, now coloured. I now put the old charging port back into the phone and it has behaved the exact same.
I have tried other screens that are cracked and broken (because its only what i had spare) however they dont show any lines, the only faults show are what was already bad with these other lcd’s. Meaning it must be something with the display correct? I didn’t do anything i don’t do with other phones that i fix fine. When i opened it, i could tell it had been repaired before (missing screws) is that relevant?
Please help, i’m on a time crunch! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like you need a new screen.
这个答案有帮助吗?
得分 1
添加一条评论
Second @tech_ni's opinion; certainly sounds like time for a new screen.
Any chance you connected/disconnected the screen with the battery still hooked up? That's been known to cause damage to screens.
It could always be a connector issue as well; in this case the fact that other screens work would tend to isolate that cause to the screen's connector and not the motherboard's. Get out the magnifying glass and a bright light and go over the connector and the flex cable looking for bent, broken or missing pins or any kind of damage to the cable itself.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jack Chadwick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 209
