跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
My iMac won’t turn on after power outage
Can’t get my computer to come on. Tried all the comments on how to fix it , but nothing is helping . It’s dead. I know it’s a late model but I like the way it operates and not in financial position to buy a new one . Any help would be appreciated.
I am about to try and take it apart .
thanks in advance
laurie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your system has some onboard diagnostics LED’s which is located in the bottom right side of your logic board just out of sight by the chin plate and a strip of Black tape covering them. Follow this guide to Step 10. Using a keyhole flashlight and a pair of tweezers carefully lift off the tape covering the LED’s
Note the LED’s are read Right to Left!
LED #1 - Indicates that trickle voltage from power supply has been detected by logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when computer has been shut down or put to sleep. The LED will turn off only if AC power source is disconnected or power supply is faulty.
LED #2 - Indicates that logic board has detected power from power supply when computer is turned on. This LED will be ON when computer is turned on and power supply and voltage regulators are working correctly.
LED #3 - Indicates that computer and video card are communicating. This LED will be ON when computer is communicating properly with video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then video card might be installed incorrectly or need replacement. Note: LED #3 is not present on models with integrated graphics.
LED #4 - Indicates that computer and LCD panel are communicating. This LED will be ON when computer is turned on and video signal is being generated. If LED 4 is ON and there is no image on display, then LCD panel, LED backlight board, or cables between might be installed incorrectly or need replacement.
Tell us what you discover
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laurie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 57
