跳转到主内容
The Ecovacs Deebot 900 is an autonomous robot that vacuums the floors of your home. This page includes repair guides and troubleshooting tips.
6 个问题 查看全部
How can I change the Ecovac Ozmo Deebot 950 model's Battery?
Hi.
It is not listed here, so I choose the closest to my model number. I would like to know how I can change the Ecovacs newer model Deebot Ozmo 950 (with mopping) . I would like to do this myself. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
There are two screws right behind the front wheel, holding the battery compartment. Simply open it and pull the connector of the battery.
这个答案有帮助吗?
得分 0
添加一条评论
This Version is pretty similar to the Deebot 900 but still slightly different. On the bottom side you need to remove the cover with 8 screws (slightly shaking the plate to help it get loose):
After this you can already see the battery behind a metal block with two screews:
Try to lift the metal block after unscrewing (lifting the battery at its two white strips slightly might help here)
Then unplug the cable and there is the battery:
and the bot looks empty:
这个答案有帮助吗?
得分 0
添加一条评论
I have a 920, which is only slightly different than the 950.
Cover removal is the same, but the metal block securing the battery covers the entire thing.
It's substantial too!
Also several years back after first purchasing this, I modeled/printed this exhaust manifold to clip onto the exhaust vent. Because the side exit exhaust design is just plain silly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 34
总计 1,338
