Xbox is flashing orange, then turns off automatically.
it was working before i opened it, help!
Orange flashing:
Problem: If there was a mod installed then it is most likely due to a solder splash, solder bridge, or a broken trace.
Fix: Search around to see if you can find a solder splash, solder bridge or cut trace. If you find either of the solder problems desolder them.
Why did you opened the console at first place? Anyway, also make sure everything is connected as it should and that it’s not overheating.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 79
总计 2,975
7条评论
i wanted to blow it out with compressed air, it was never opened before so there was no modchip. i also checked the motherboard and there is no solder slash or bridge.
由 patchedmac 完成的
Did you also checked for broken traces? Could also be corrosion on the motherboard it self (and on traces). Did you cleaned it with isopropyl alcohol?
由 koppie007 完成的
I'll clean the motherboard and then post if it worked.
由 patchedmac 完成的
did not work
由 patchedmac 完成的
Please see this thread: https://www.reddit.com/r/originalxbox/co...
Could be the clock cap.
由 koppie007 完成的
显示更多的2条评论
