跳转到主内容
The Palm Treo 680 is a the first Treo based smartphone to have the external antenna removed.
7 个问题 查看全部
问题已关闭
I want to erase memory from phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Give us a bit more info about what you are trying to do? you want to clear some memory? Are you running out of memory?
完成的
添加一条评论
1个答案
已选择的解决方案
bahamaina, this will clear ALL YOUR INFORMATION, so only do it if that is what you need to do. The 680 does not have a reset button, so you need to use the battery as reset button:
-Remove the battery,
-Insert the battery, and immediately press and hold the power button.
-Wait till the first time-bar is fully loaded, and the palm logo
shows, if you can't see the screen because it is cracked, just hold
the power button for 1 minute.
-Release the power button,
-The screen says now: erase all data ? (Yes = up, No = other button)
-press the 5-way navigator to the UP position.
-Now the PDA is erasing user data. This will take about 10 seconds.
Hope this is the information you needed. Good Luck.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 745
