Why is my power not staying on?
My lower screen broke. So I replaced it, now when I push the power button, the blue light comes on for literally two seconds then shuts off. What could be the source of this problem?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 26
My old 3ds wouldn't even come on without the wifi chip connected. I'd say go back and make sure everything is connected properly
由 Roman Prochazka 完成的
I did, still the same thing happening. I really appreciate your comment though! Thank you.
由 darekbray1984 完成的
Hi!
Do you also see the screen flash for a second? Most of the time, this indicated that the ribbon cable is not fully inserted into the socket! Make sure it's all in (and yes it goes deeper then you think! I always needs to test if it works, because it's hard to see if it's all in there).
由 koppie007 完成的
Hello!
Yes, the screen does flash right before the blue power light goes off! Thank you for the tip. I will disassemble it yet again to see if that might be the issue. Thanks again.
由 darekbray1984 完成的
Alright, yes the screen that flashes white for 1-2 sec (and then turns off), is the screen which is not properly seated (ribbon cable)! You need to check that one :). And if you are there, check the other too, just to be sure.
由 koppie007 完成的
