跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
won’t turn on after screen replacement
After replacing the screen and home button, the phone will not turn on. Did I fry the logic board with static electricity or what? Any diagnostic procedures would be appreciated. I have parts from an iphone 5 if needed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello Killian,
Plug your phone into a PC, is it being recognized? If so, did you disconnect the battery first? If you didn't there's a chance one of the filters is gone. Take a strong flashlight and shine at the screen, does anything show up? It's usually the case of backlight not working. If you disconnected the battery first have a look around the screen connectors, you might've knocked off one of the microscopic components off. Next have a look around battery and charger ports for any pry damage.
It's also possible you didn't connect the battery / charge port properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Killian Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
