keeps saying code 08 but it doesn't have a reset button
Ok I bought a colman saluspa hot tub and it keeps saying code 08 but it doesn't have a reset button on the pump so is there anyway I can reset without that button?
A search pulled up that the code requires a thermal reset. This video shows the power switch being used, along with the GFI test button on the pump cord, not on the pump itself. Here's the link:
这个答案有帮助吗?
There is a reser button, it just depends on the model number where its located. Refer to the owners manual for your unit. It is available online in a pdf ,if you no longer have it.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 103
总计 3,070
Hi ,
What is the model number of the spa?
由 jayeff 完成的
Tried fix but still doesn't work. I have a similar model without a reset button on the side. Every video I've looked at shows only models with reset buttons. What's up?
由 Tibor Ouyang 完成的
@tiborouyang
What is the model number of your hot tub?
由 jayeff 完成的
model S100104
由 STEPHEN BRONN , QAFP 完成的
