跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Why is my screen showing black lines after replacing the battery?
Did I break my screen? After replacing my battery it looks like this, fickering black horizontal lines across the screen.
The phone still works but It doesn’t look good. I followed the guide perfectly and was extra careful with the connectors, I tried cleaning with contact cleaner the connectors and the ports but no success.
Anything else I can try before having to buy a new screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Sadly with the iPhone 5 series like the 5, 5S, 5C, and 1st gen SE, they all suffer from this issue of the display getting damaged during battery replacement regardless of how careful you are while attempting the repair. All you need is a replacement screen assembly and you should be fine. As a repair shop, I even replace the battery without disconnecting it and I still sometimes have this issue.
这个答案有帮助吗?
得分 2
1条评论:
I had no Idea it was that fragile! I did not read about that
完成的
添加一条评论
添加你的答案
ALBERTODELAVEGA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 165
