跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1005 个问题 查看全部
iPhone 6s Plus home button working on and off
I have an iPhone 6s Plus with a on and off working home button, I have replaced the home button and it does the same thing, it will work for a while and then it just stops working, just to work again later on. One of flex cable connectors at the top of the screen (specifically one for the home button) is slightly split. Would this be the cause?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, replace the screen and it should fix your problem. If you have the factory home button I would put it back in so touch Id will work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rileytucker2211 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 34
