跳转到主内容
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
30 个问题 查看全部
Possible to replace ipad mini 3 logic board with one from a mini 2?
Hi, i got an ipad mini 3 with touch problems, thinking i would replace the digitizer and be done with it. When replacing i noticed that the problem was with the fpc connector, and since I do not have the micro soldering capacities to deal with it, I was thinking if it was possible to replace the logic board with one from a mini 2, and use a mini 2 digitizer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No. You can't replace the logic board from one ipad to another unless they are the same model. Same thing with batteries, charging ports, etc.. why would apple want to make parts interchangeable. It's a bad business model if you want to sell new ones. Apple doesn't even make it easy to repair them.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
ericsancha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 224
