跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Could a faulty screen cause the phone to keep restarting?
I was given an iPhone 6sPlus, The phone restarts at random. It took several tryes to finally get through setting the phone up, just getting through the set up. I just want to use the phone to try different things with that I would not do with my personal phone. Every once in a while white lines go across the top of the phone and the touch does not work. Could this be a part of the reason it would restart at random?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Grey / white Horizontal lines at the top with no touch indicate a touch IC fault. Will require a reputable repair shop that does micro-soldering for iPhones to fix.
Restarting on the other hand can be a worn out / bad battery.
这个答案有帮助吗?
得分 1
2条评论:
The touch only goes out at random, I can usually squeeze where the screen connects to the logic board and it will work. So I don't think its the touch IC, usually if they go bad, you can not get touch to work at all.
完成的
That's exactly how the touch IC behaves. It develops loose solder balls / traces under the chip which causes an intermittent connection. Bending / flexing of the screen can temporarily restore touch as it applies some pressure to the chip.
If it's grey horizontal bars at the top it's 100% touch IC fault. Check first 30 seconds of this video:
https://www.youtube.com/watch?v=jq7COeOx...
完成的
添加一条评论
添加你的答案
Brent Norris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 15
总计 399
