removing the last ribbon cable
Hello,
I am trying to detach this ribbon cable and pinching the side tabs does not release it.
Does anyone recognize this specific type of connection. Is there a trick to it?
thanks
Ken
Of course the solutions is similar to other ribbon cable releases.
Flip up the bar located in this photo and then the release tabs on the sides will work as expected.
这个答案有帮助吗?
You might have already done this but, have you tried sliding them little side bits up as the arrows are pointing up and it looks as if there is a gap there for this.
Not 100% Maybe wrong.
Please comment how you have figured this out if you get this so others can see this if they have the same issue.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 849
2条评论
由 KSP Electronic Repair 完成的
Thanks Kieran. I did try that. Will definitely post the solution when I figure it out.
由 Ken 完成的
