White lines on screen, and digitiser unresponsive
I replaced the camera on an iPhone 6 however, there are now white lines visible on the screen and the digitiser is unresponsive.
Make sure all connections are seated correctly as I had this issue my self everything looked as if it was connected but once disconnected & reconnected properly this seemed to fix my problem.
If this doesn’t work let me know and I will try help further, if i can.
这个答案有帮助吗?
Also with the iPhone 6 & 6 Plus, they are very common to touch disease so this could also be the cause of your issue.
@kieranp21
The phone was working perfectly fine before (in regards to the touch screen). I tried your solution, but it seems to have gotten worse, with the lines now flashing.
That worked for me the first time round one time i had a 6 come in for the same fault i tried re seating the connectors and as you said it got worse i had a spare screen on hand so i tried a new high quality screen and that worked with no issue.
If you have a screen i would try that if that doesn't work then it sounds like you may have a logic board issue.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
