跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
97 个问题 查看全部
Replaced damaged display but nothing shows up
I replaced the damaged LCD display with one from iFIxit but when I turn on the iPod it shows nothing on the display. The backlight works; I can hear the drive spinning; and I can play songs but no menu or song info shows on the display. I'm going to try retracing my steps and making sure that all connectors are on solid. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
这个答案有帮助吗?
得分 1
2条评论:
I highly doubt resetting would work here.
完成的
Yes, resetting the iPod didn't help; both before and after reinstalling the display. I've asked ifixit support for help.
完成的
添加一条评论
That sounds good, open it back up and try reinstalling the display.
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately, that didn't help.
完成的
添加一条评论
添加你的答案
russtoku 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,316
