跳转到主内容
The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
Power button may be stuck, the tablet just continues to reboot
I dropped it and now the power button is slightly off (seems to be stuck in to the case on the bottom of it) and so it keeps coming on with ASUS and Medaitek screens but then immediately reboots. Any ideas of how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could open easily removing the 2 screws, remove the sd card and follow youtube instructions. When it’s open unplug the buttons connector. If the tablet stop rebooting is problem of the buttons if not I don’t know. The buttons could be easily bought on ebay. If the tablet stays switched off you could switch on with a small screwdriver touching in two pins at the back where you unplugged the buttons flex cable. You could also try how reacts when you charge and so on to discard battery, charging port…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
C. M. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 328
