跳转到主内容
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
332 个问题 查看全部
Replace HDD for HDD Box Buffalo MiniStation 2,5" USB 2.0?
Please do me a favor to guide me how to replace HDD on HDD Box External Buffalo MiniStation (2,5" - USB 2.0). I 'd like to replace the HDD inside that box. This is the link of product, it's quite hard to open (no screws +_+):
http://www.buffalo-technology.com/produc...
Pls help me ASAP. ^^
Thank you so much in advance
I love your site ^^
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Please, anyone? +_+
完成的
I need helpppppppp +_+
完成的
This question was migrated from http://meta.ifixit.com/Answers.
完成的
I still need your help! +_+
After few weeks, I'm still waiting for a solution! +_+
完成的
添加一条评论
5个答案
已选择的解决方案
I can find no information on dis-assembly of this unit. Looking at the photo of the unit it appears there is a seam going around it. You might try using a Spudger to go around that seam to see if that gives you access to the drive for replacement. Good luck.
Metal Spudger Set
这个答案有帮助吗?
得分 4
2条评论:
Thanks for your answer,
I think so, but actually I'm afraid my outside box will be damaged.
Should I take some photos close up to all of my device's sides and show to you to get an advice?
Have a nice day! ^^
完成的
You could call the maker and ask for service. Ask them how to open the device. As I said I could find no information on procedures for replacing the drive--I think they may want you to pay them to do it. There is always risk in trying a procedure like opening a case--you have to decide if its worth the risk to you.
完成的
添加一条评论
It has a two year warranty.
这个答案有帮助吗?
得分 3
添加一条评论
I made a guide for this, hope it helps.
Disassembling Buffalo MiniStation External Hard Drive (Thunderbolt & USB 3)
这个答案有帮助吗?
得分 1
添加一条评论
Thanks guys, Actually, I bought this device in Korea and there is no official reseller or global warranty in Vietnam for it! +_+ So, I will leave this topic open and welcome all the ideas coming before I break it up! ^^
这个答案有帮助吗?
得分 0
添加一条评论
just put an ATM card inside the edge, then lift it up slowly, starting from the long edge!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
quangtrungdesigner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,496
