跳转到主内容
The K-Gro Power Pro Push mower, manufactured by Modern Tool and Die Company.
5 个问题 查看全部
Need front and rear wheels. Model RBSP205A
Need front and rear wheels for my lawnmower
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
After searching for it a little bit I couldn’t find any spare wheels for your model.
If I understand you correctly, you are planning to replace all four wheels, so it would work if you get any wheels that have the same mountings and are about the same size as the old ones (just measure so they are big enough so the body isn’t laying on the ground and small enough to fit).
If you add pictures and measurements for the mounts and the size of the wheels, then someone may be able to found some that fit. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
Hi @garage45
Here’s a link to the parts diagrams for your model.
Click on the rbsp205a.o1 link to get the parts diagram that shows the rear wheels with flange lock nut and hub cap
Click on Index numbers 37, 38 & 40 and then click on Process Choices, to get the prices and the part numbers for the parts. If you search online using the part number only for the wheel and the flange nut, you will get results for other suppliers for these two components, that may suit you better. This method didn’t work to find any other suppliers for the hub cap though
Click on the rbsp205a.o3 link to get the parts diagram that shows the front wheels with flange lock nut and hub cap
Click on Index numbers 27, 28 & 30 and then click on Process Choices, to get the prices and the part numbers for the parts. If you search online using the part number only for the wheel and the flange nut, you will get results for other suppliers for these two components, that may suit you better. This method also didn’t work to find any other suppliers for this hub cap either
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharon3 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 182
