跳转到主内容
加入维修社区 - 创建账户
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
I calnt turn on my tablet
i think my power button flex is broken or something, what should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello. Can someone help me regarding on my xperia tablet z issue. Beside the power button the red light is not turning off. What will i do??? Please help meee. I dont know what to do :(
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @ramonb,
Is the tablet’s charging indicator light red, orange or green when you connect the charger to the tablet’s USB port?
If it is red or orange allow the tablet to fully charge (light turns green) and then try to turn on the tablet with the charger still connected. If it turns on with the charger connected, the battery may be failing and will need to be replaced. Here’s the ifixit Sony Xperia Tablet Z Battery Replacement guide which may help. Replacement batteries are available online. The example is only to show what it looks like and how much it may cost. There are other suppliers that may suit you better. Just search for Sony Xperia Tablet Z battery to get results for suppliers that suit you.
If the charging indicator light does not turn on at all when the charger is connected, using a different compatible USB cable, connect the tablet to a working USB port on a computer and check if it starts to charge.
If the charge light turns on when the tablet is connected to a computer then the charger or the charger’s USB cable is faulty and needs to be replaced. Allow the battery to fully charge before attempting to turn on the tablet. A computer’s USB port will charge the battery more slowly than the charger as it only supplies 0.5A as opposed to the charger’s 1.5A, but it will still charge the battery, especially if the tablet is not turned on
If the charging indicator light does not turn on at all when the tablet is connected to a computer, then perhaps the power button is not the problem but it may be that the battery may be fully discharged due to a faulty micro USB port. Use a strong light and a magnifying glass to visually inspect the tablet’s micro USB port enclosure to make sure that the is no lint stuck in the port preventing a good electrical connection and that all the pins are there and that they are all straight and parallel with each other and not bent, broken or missing. If there is any debris stuck in the port do not use a metal pin or probe to try and get it out as it may damage the pins or cause electrical problems in the tablet, use a vacuum cleaner instead to try and suck it out. If it won’t come out then use a sharpened wooden toothpick to gently prise it out.
If the USB port enclosure appears to be OK, then the tablet will have to be opened and the USB port tested to make sure that it is OK. Here’s the ifixit Sony XPERIA Tablet Z Micro USB Port Replacement guide that should help. If the USB port is faulty, (loose?) suppliers - example only of the part are available online. The example is only to show what it looks like and how much it may cost. There are other suppliers that may suit you better. Just search for Sony Xperia Tablet Z usb charging port to get results that suit you.
If the USB port tests OK, then there is a motherboard problem
If the charging light turns on and is green but the tablet doesn’t turn on then as you say it may be a power button problem.
Here’s the ifixit Sony XPERIA Tablet Z Motherboard Replacement guide. At Step.8 in the guide it mentions the removal of the headphone jack, power button flex cable. Again suppliers - example only are available online. Just search for Sony Xperia tablet Z power button flex cable to get results that suit you.
Hopefully a start to find the problem.
Sony Xperia Tablet Z Battery图片
指南
难度:
中等
Sony XPERIA Tablet Z Micro USB Port图片
指南
难度:
中等
10 minutes
Sony XPERIA Tablet Z Motherboard图片
指南
难度:
中等
1 hour
这个答案有帮助吗?
得分 0
2条评论:
it is fully charged and on the home screen and all works, but whain it goes to sleep i need to conect the carger
完成的
@ramonb
Does it start up OK if you turn it off and then turn it on again or do you need to use the charger as well to start it again?
Or does it only need the charger when the tablet screen turns off after the screen timeout period has elapsed?
完成的
添加一条评论
添加你的答案
ramon burf 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 47
总计 4,723
