Acer Iconia Tab W500 SSD/Ram?
Is there a way to replace the SSD on the Acer Iconia Tab W500 and the Ram? I want to replace the SSD with a 1TB instead of using the 32gb one.
Acer W500 uses mSATA ssd. Currently you can upgrade it upto 128GB. Regarding RAM, as per C50 processor specification, you can upgrade it upto 4GB but the existing 2GB ram sitting behind the processor and it is soldered to it.
I have upgraded my SSD to 64GB, but I did not upgrade the RAM.
I really enjoy using this tablet.
这个答案有帮助吗?
Hi,
The Iconia Tab uses mSATA SSD drive, so is it possible to upgrade SSD to 128-256 GB, but not more because is not available 1TB SSD.
这个答案有帮助吗?
Hi,
Now 1TB mSATA SSD (Samsung 840 EVO) is available. So does Iconia Tab W500 support that 1TB mSATA SSD?. Can any one confirm ?.
Thanks.
I recently upgraded my W500 SSD to a Mushkin 240GB mSATA with no issues.
Only requirement was first flashing BIOS with latest version from Acer
这个答案有帮助吗?
I have not found anyone that has torn it apart but you can check the forums at http://forum.tabletpcreview.com/acer/
这个答案有帮助吗?
过去的24小时: 1
过去的7天: 18
过去的30天: 49
总计 20,116
How do qou flash bios in acer w 500
由 Rae Lockwood 完成的
Is it possible to add a second SSD to Iconia Tab W500 internally ?. Has anyone tried it ?.
由 BNMS 完成的
Hi,
What is known RAM?
由 picsama 完成的
