跳转到主内容
The Plantronics BackBeat Go 410 is a noise canceling wireless earphones.
5 个问题 查看全部
BB Go 410 “Power on" then unusable. How to fix this?
I have a unit of BB Go 410 that when turned on says “Power on" then stop and unusable. If normal it should says “Power on, battery high/medium/low”, then usable (directly to music or anything else I'm listening to). I can still charge it and the lamp indicator can still show whether it's charging or full.
In my case usually if I leave it for hours it went back to normal and I can use it, but it keeps disconnected from my phone until eventually it went back to the previous state (“power on" then unusable). While in my wife case (a different but same type unit) every time we try to turn it on its always “Power on” then unusable.
Any suggestion to fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
1 Side Sound Not Working
这个答案有帮助吗?
得分 2
添加一条评论
Hey,
4 years after your message, the same thing is happening to me. Any chance you found a solution but didn't post it here... ?
Thanks so much.
这个答案有帮助吗?
得分 0
1条评论:
I tried resetting to it to factory settings using the Android App, but it didn't work...
完成的
添加一条评论
same happened. fixed it bypressing all buttons in many combinations for a long time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zulfikar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 33
总计 453
