跳转到主内容
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
61 个问题 查看全部
How do I get the tire back on the rim
Hi I have a flat…hope am I suspose to put the rubber back on the rim
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
Take the wheel off of the mower. Lay it flat on concrete. Get some vaseline and rub it against the bead of the tire and rim on both sides. Remove the valve core which will let in a lot more air. You need a compressor and not a little one, you need one with a tank on it. You could also use starting fluid or brake cleaner to inflate it but I wouldn't recommend that if you have no experience doing that. If you can't get to air up take it to a tire shop. They will air it up most likely for free.
这个答案有帮助吗?
得分 0
添加一条评论
You best bet is definitely a tire shop, if you don’t have experience mounting tires.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KAREN Martin 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 104
