跳转到主内容
Bluetooth gamepad by Asus, sold with the Nexus Player.
1 个问题 查看全部
My right axes goes leftward always
Hi, guys, i've just brought a controller Sven GC-2040 and start to configurate this for FIFA 20 and have one problem.
Sorry, I put wrong Device cause I couldn’t found my joystick.
You can see in pictures the issue. The right stick goes left always.
https://imgur.com/JxnUlTB
https://imgur.com/GiA7xkj
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Adamo Official  … this as a common issue that happens to all controllers at some point. the reason is either the internal housings bands that keep the stick straight are broken or stretched, or that there is dust or debris preventing the stick from returning to its neutral state. you can follow this guide to disassemble the device and attempt to clean the housing with isopropyl alcohol:
ASUS TV500BG Bluetooth Controller Disassembly
if cleaning doesnt fix the issue, or you see the bands are stretched or damaged, you can replace the controller housing. this will require tools and experience. the parts for this particular controller isnt advertised, but this is a standard part for controllers of this type. here is a link for a potential match ( youll want to verify pins and shape while you have the device open) , but you can see that this part is for playstation, xbox and possibly yours as well:
https://www.amazon.com/EEEKit-Replacemen...
if this doesnt match the profile of yours, just google joystick replacement parts and find a match.
post back with any other questions if needed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adamo Official 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 110
