跳转到主内容
A 17 inch laptop equipped with an Intel Core i7 CPU.
Laptop won't come on if unplugged
Display is showing full charge but won’t come on if it’s unplugged. Does the battery need to be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
If Windows10 is installed, create a Win10 battery report to check the condition of the battery.
It may be that even though it shows that it is fully charged, it may not be able to supply the necessary power when under load.
这个答案有帮助吗?
得分 0
1条评论:
Thanks so much for the help!
完成的
添加一条评论
Yea, the battery is done. Go ahead and replace it cuz it holds no charge at all.
这个答案有帮助吗?
得分 0
1条评论:
Even though the display shows a full battery?
完成的
添加一条评论
添加你的答案
cindylulu15908 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 279
