跳转到主内容
修复你的物品
维修的权力
商店
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
219 个问题 查看全部
Slow and Laggy 2011 Mac Mini
My Mac Mini is quite slow and laggy. I have to experience a lot of spin wheels even for the simplest of tasks such as right-clicking to copy or paste something.
  • macOS 10.13.6
  • 2.3 GHz Intel Core i5
  • 5 GB 1333 MHz DDR3
  • Intel HD Graphics 3000 384 MB
I currently have 4 GB and 1 GB memory cards, however even with 2 x 4 GB cards I still experience the same problems.
It cannot handle more than 3 basic apps running at the same time. I usually have Safari, Mail, and the Music apps running all the time but if I decide to open anything else e.g. Photos, it becomes extremely slow forcing me to close one of the apps.
It also struggles with more than 6-7 Safari tabs depending on the webpages.
I often listen to a music playlist on YouTube and maybe after 15-17 songs, I have to close the tab and open a new one. It warns me about using significant energy and if I ignore it the device runs slow.
I am only using two extensions for Safari, Grammarly and AdGuard.
I am only performing the most basics of tasks on this device and it struggles to keep up with it.
I don’t want to buy another Mac, new or used. I am sure there is something that can be done to fix this issue.
I have these apps installed on my Mac which I believe are quite basic apps.
AdGuard for Safari, Android File Transfer, App Store, Automator, BitTorrent, Calculator, Calendar, Chess, Contacts, DaisyDisk, Dashboard, Dictionary, DVD Player, Express VPN, FaceTime, Font Book, GarageBand, Chrome, Grammarly, iBooks, Image Capture, iMovie, iMovie 9.0.8, Install OS X El Capitan, iPhoto, iTunes, Launchpad, Mail, Maps, Messages, Microsoft Silverlight, Mission Control, Notes, Numbers, Pages, Photo Booth, Photos, Preview, QuickTime Player, Reminders, Safari, Siri, Stickies, System Preferences, TextEdit, Time Machine, VLC,
Thank you for reading.
Cheers!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
What is your drive and its size? How full is it?
Also lets try running the onboard diagnostics restart your system and press the D key
Reference: Mac startup key combinations Let us know what you get for an error.
完成的
Thank you for your response.
500 GB SATA Disk, 250 GB used.
I ran the test and it returned with no errors.
完成的
I can constantly hear the device doing something. Definitely not the fan, maybe the drive?
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
2个回答
最有帮助的答案
The real issue is the HDD over time gets fragmented. Getting a defragmentation app to undo the fragmentation or backup the drive fully and reformat it will also work.
Replacing your HDD with SSD is also a good direction or what I would do is add the SSD! 为 Mac Mini 中期 2011 安装双硬盘组 That way I can make the SSD be the boot drive with my apps and leave my stuff on the HDD. That way you don’t need as large a drive! A 250 GB would be more than enough for most people!
这个答案有帮助吗?
得分 1
添加一条评论
Oh Man! Just replace with the SDD and you are good to go.
这个答案有帮助吗?
得分 0
评论:
Yes, I might just do that. I will upgrade the size too.
完成的
添加一条评论
添加你的答案
Abhishek 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 13
总计 69
