My samsung tv #QN75Q7FAMFXZA won't turn on
I think it’s the power supply, where can I get parts and how to
with a no turning on situation, youll want to ensure that there is indeed no power be supplied to the set. to acheive this, youll want to remove the back cover and check the outputs at the connector leading to your main board. with the device plugged in, but off…you should have your standby voltage on one of the pins labeled accordingly. (stby) if this is present, after hitting the power on button, you should then see your other voltages, 12v ,3.3 etc. on the other pins of that connector. if none of these are present, you can troubleshoot the power supply. if those are there, its something else. post back with your findings and some pictures of the interconnecting of your boards for further assistance.
这个答案有帮助吗?
Did you get it repaired? I have similar problem with my. It has power only every other day. I have to unplug it from outlet for couple days and then it turns on again
We're you able to get your Samsung Q7N TV working?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 1,133
