跳转到主内容
修复Nintendo Switch Joy-Con控制器的指南和信息。
167 个问题 查看全部
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
3个答案
最有帮助的答案
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
这个答案有帮助吗?
得分 2
添加一条评论
Did you try updating controllers? It worked for me
这个答案有帮助吗?
得分 2
添加一条评论
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Falling Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 99
总计 5,737
