跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
iPhone X is dead
Hello.
A customer recently came in with he’s iPhone X and explained that it just died. It won’t turn on and it won’t charge.
I tried charging it while using a USB voltage meter and it showed 0A. I suspected the battery and tried to replace it but still no sign of life or charge in the phone. I then connected the phone to a DCPS to check if there is a short in the motherboard but it showed no short at all. I suspect one of the IC’s related to power management is dead but i am not sure where to start.
Anyone with similar issue that has a fix or can tell me what to do next?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sounds like a board level issue. Send it to a board repair specialist like iPad Rehab or STS Telecom or Louis Rossmann.
这个答案有帮助吗?
得分 0
1条评论:
I know it's a board level issue. "I suspect one of the IC’s related to power management is dead but i am not sure where to start."
I do board repairs myself but have never seen this issue in an iPhone X. I was hoping i could get someone who has experienced this issue before to tell me where i should star. That way i,m saving time.
完成的
添加一条评论
You can check DM readings on the FPC’s to see if anything is off… check voltage readings at battery terminal FPC to see that Tigris and Hydra are doing there job… I have also seen middle layer with separated pads that needed jumpers and others needed a reflow. What does it do on booting from DCPS? does it connect to 3utools (computer)?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Total Repairs AS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 110
