跳转到主内容
加入维修社区 - 创建账户
2014 年发布的联想游戏笔记本电脑,配备 Nvidia 860M 显卡和 15.6 英寸显示屏。2015 年更新为 960M 显卡。
Lenvo Y50-70 Charging Port wiring on mother board
Hi,
My lenovo y50-70 charging port wires detached from mother board , I have to solder it again but there is no wiring connection indication on motherboard . Anyone can please share how to solder these wires on mother board ? which wire for which point?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This may help:
http://www.s-manuals.com/notebook/lenovo...
Have you tried taking a high resolution photo of the motherboard or using a magnifying glass or loupe to look closely at the board. You should be able to see where the connections were. A broken wire end or some other disturbance at the solder pad..
这个答案有帮助吗?
得分 2
2条评论:
I checked and came to that charging ics had burnt and I am unable to see ics number as well. Is there anyway to get charging ic numbers?
完成的
Hi @Muddaser Talal
You should be able to find it if you search through the schematics I pointed to you above.
完成的
添加一条评论
添加你的答案
Muddaser Talal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 568
