Ticking sounds coming from temperature control panel?
I have a Kenmore top mount refrigerator, model 253.6292, 6 years old. The freezer section is auto defrost. Yesterday I noticed the fridge sometimes makes ticking sounds that come from the temperature control panel inside the fridge section. The same ticking sounds also seem to come from inside the back wall of the freezer section (right top corner). From reading about how fridges work, I concluded that the ticking sound quite possibly come from a timer that controls the fridge, perhaps the defrost cycle since the ticking sound also comes from behind the freezer wall. Both fridge and freezer seem to be working fine, except for the ticking sound, which I can sometimes hear when the compressor is running, but also sometimes when the compressor is not running.
Could someone please give me some input as to my suspicions? Does it sound right that the ticking sounds in the locations I described could be coming from a timer, possibly from a defrost timer? If so, is this something one can fix oneself or does it require an expert to fix it? Does it even need fixing, since fridge and freezer both seem to be operating properly? (Maybe the ticking sound is just a “cosmetic problem”, not an operational one?)
I would appreciate any input I could get. I know absolutely nothing about fridges, but it seems like if it’s only an issue inside the temperature control panel, it may be a part that I could easily replace myself. Thank you very much!
