跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for Compaq laptops produced by the parent company, HP.
116 个问题 查看全部
My laptop connects to my phone's Wi-Fi zone but not to my house Wi-Fi
It's a Compaq CQ45 Windows 8 but I just updated it to Windows 10 to see if that could fix the internet problem but it didn't. Sometimes I get to connect the laptop to the Wi-Fi but it's really weak and it often disconnects very soon. But it easily can connects to my phone's Wi-Fi zone without any problem. In other laptops the Wi-Fi works well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
最有帮助的答案
Hi Bea uwu
there are some ways to try,
On the device manager, what is the manufacturer and model of the wifi card?
  1. try updating the wifi drivers manually.
# check if the antenna cable is connected properly to the wifi card
  1. if you have a spare wifi card, swap and see if it works.
  2. if the signal is still bad with the swapped wifi card, there is a possibility the internal antenna could be faulty.
you may follow the below guide, page 7 for the wifi card location
http://h10032.www1.hp.com/ctg/Manual/c01...
这个答案有帮助吗?
得分 1
评论:
Hi,
To add to the answer place the as close as possible to the WiFi router and check if the connection holds.
If it does this usually points to an antenna problem.
I'm thinking that the phone is a lot closer to the laptop when you tried this than the WiFi router was ;-)
完成的
添加一条评论
添加你的答案
Bea uwu 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 14
