跳转到主内容
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
81 个问题 查看全部
Frigidaire LFHT1831QP2 not freezing
My refrigerator freezer is not freezing i replaced parts for thermostat .thermistor control board. and start relay ,and capacitor all fans are running what else could it be and some frost on one botton coil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Have you checked that the condenser coils are clean and free of dust?
What is the temperature in the freezer and refrigerator compartments?
You said that there is frost on one bottom coil, do you mean the evaporator unit inside the freezer compartment?
If so and assuming that the compressor is running (is it hot to the touch?) then it may be that there is a blockage in the sealed system.
Post some images showing the frost on the coil.
Here's how to do this
在已经存在的问题里加入图片.
Also check for any oily residues below the compressor or on the condenser coils near the compressor. If there are this may indicate that there is a leak in the sealed system.
这个答案有帮助吗?
得分 2
1条评论:
Hi,
Have you checked that the defrost heater is OK?
You need to defrost the ice .Don't use a hair dryer on high as it may damage the evap unit. Use it on low only for brief periods to help speed the melting up. Turn off the fridge and leave the freezer door open
Then with the power still disconnected from the fridge, disconnect the heater element below the evap unit and test it with an Ohmmeter. Usually they test 20-50 Ohms
Just verifying that the evaporator fan operating?
If the compressor is running then if you manually operate the door switch (should be located in the door jamb of the refrigerator) the evaporator fan should start running. When you release the switch the fan should stop.
The door switch not only operates the light in the fridge but tells the control board to turn off the evap fan because the door is open. manually operating it with the door open, fools the control board into thinking it is shut. This allows you to observe the operation of the fan.
完成的
添加一条评论
添加你的答案
sandra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 570
