跳转到主内容
A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
29 个问题 查看全部
My whammy bar isn't workin
I have a ps3 les paul guitar and my dog ended up knocking it over, ever since then the whammy bar doesn’t work, it still has tension it pulls back its not flopping down or staying flat but when i try to use it, it does nothing, i need help please and thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
youll want to follow this guide:
Les Paul Wireless Guitar Body Teardown
this will allow you to open the devoce and obtain access to the whammy bar. there youll want to inspect and see if there is any solder joint broken or loose wire due to the drop. if nothing visual is seen, it could be damaged internally and may want to consider replacing it. you can find the replacement here:
Les Paul Wireless Guitar Peripheral Whammy Bar Replacement
report back here with findings for any additional assistance if needed.
Les Paul Wireless Guitar Whammy Bar图片
指南
难度:
中等
5 minutes
Les Paul Wireless Guitar图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
1条评论:
Will do, thank you for the reply
完成的
添加一条评论
添加你的答案
Tiberius 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 241
