跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
What should I do to stop recieving a temperature warning?
So, recently I bought a couple of broken iPhones from the internet and one of them is working just fine except that I keep getting that annoying message all over my screen about my iPhone needing to cool down. I’ve replaced the battery and even moved the logicboard to a different, working iPhone and the issue is still there. So it’s either a problem with the logicboard (which I find unlikely) or software. Any ideas? (btw, It’s not even getting much hot at all).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is your iPhone getting very hot? If so, there’s some sort of issue with the board that’s causing it to heat up to the point where the phone is considered unsafe to use. If it’s not heating up, just giving you an annoying notification, then there is likely some sort of issue with the temperature sensor on the board. Does the inside of the phone have any clues as to if it’s been water damaged before?
这个答案有帮助吗?
得分 0
3条评论:
I mean as I said these are some used phones I bought and I opened'em all up and neither on the inside or the outside I see any signs of water damage, the phone is generally in a good condition, though I am not a technician so I might be wrong. I can provide some pictures If you want.
完成的
Oh, and also, yeah technically it gets a little bit hot at first but after some time it's not even warm but the warning still appears.
完成的
You could try doing a DFU restore on the phone to put fresh software onto it, that way software can be ruled out
完成的
添加一条评论
添加你的答案
Joachim Sterna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 77
