跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Bizarre problem after changing logic board
Hi
Ok do I had a mint condition iPhone 4 which had an activation lock . I changed the board for one in an old iPhone 4 I had which I knew the iCloud details
All went well the phone powered up , I disabled FMI and signed out if iCloud
I then erased all content and settings and to my horror was greeted with the activation lock screen bound still to the iCloud of the logic board I removed ?
How is this possible ? Is there another component aside from the logic board that stores the phones serial number etc ? I'm baffled and have never seen this before in countless others I have done
Any help greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
No this doesn’t sound possible, unless it was somehow cloned many years ago. The serial and IMEI number are programmed into the CPU of the motherboard. A housing and screen swap can have no influence on the serial number or IMEI number.
这个答案有帮助吗?
得分 1
1条评论:
I know , I agree with you completely but this is happening. It's 100% got the new board installed in it as I used it for a while with my old iCloud before signing out and resetting the phone . And now it asks for the same email address to activate that was already on it before the logic board was removed - which is sat on my kitchen side !
I still tried my original iCloud to activate even though I had turned it off but to no avail
I'm stumped I have no idea how this could be possible
完成的
添加一条评论
添加你的答案
Dave Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
