跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Samsung TV.
Why won't my tv auto program?
Why won’t my Samsung tv auto program?
Update (07/07/2020)
Model # UN40H5003
Auto scan for channels
Antenna connection.
Note: Tv less than 3 yrs old when stopped working properly. I expect a tv to last longer. I know you will make this right. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
What is the model number of the TV?
By "auto program" do you mean auto scan for available TV channels?
If so are the channels from an antenna connections or a cable connection?
完成的
Still not working. 1 channel. Can’t believe a Samsung tv does not last even 3 years. I have done everything ypu have asked of me and still nothing. You need to make this right or direct me to a person that will help.
Thank you
Joy
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Have you checked that the TV is setup to receive TV signals from an antenna or a cable service i.e. Air or cable?
Here’s how to do this in your TV. Scroll down to Memorizing Channels
这个答案有帮助吗?
得分 2
5条评论:
Hi @ joy palmieri
Is the TV getting the signals from an antenna or a cable "box" you didn't say?
完成的
its placed on antenna under settings
完成的
why does it keep stop programming and immediately shut off
完成的
the tv will only auto scan for channels up to 4 to 6 % then shut off so it only has 3 tv stations
完成的
why did this conversation just stop samsung ?
the lose of channels now 2nd august 2024 is happening across kent ... this morning auto tune even disappeared from view or use ? .. yes i have a samsung tv
i read that the bbc suggest unplugging the aerial and using auto tune (knowing the transmitter name) ... is this going to fix the channels just disappearing suddenly?
we are in the olympics window and the bbc channels in particular are disappearing
完成的
添加一条评论
添加你的答案
joy palmieri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 2,947
