Not booting- 1 beep every 3 seconds
I have an old 2008 iMac.
We are doing some home renovation and when we plugged the computer back in, it did not boot- the start up chime played and then a beep every 3 seconds.
I replaced the ram with ram from owc (same as previously). I cleaned contact surfaces with an eraser-in the computer as well.
I’m getting the same beep. I tried to start up in safe mode, etc- did not work. If left long enough, the beeping stops and a white screen remains.
Then if more time goes on, the Apple symbol comes up, then goes away- replaced with a 0 with a line through it. Then the ample symbol again- but nothing past that.
Any thoughts?
We live 2 hours + away from the nearest Apple store.
If I have a big issue, I don’t know if it is worth pursuing fixing - or if I should just admit defeat and purchase a new Mac. My files should be saved on an external drive, so I’m less concerned about what is actually on the computer.
Thank you so much in advance.
1条评论
Your system is too old to be fixed at an Apple Store Vintage and obsolete products
由 Dan 完成的
