跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
386 个问题 查看全部
Can no longer charge iPhone 8 Plus
Last week, I was having trouble getting my iPhone to charge via the lightning port. I tried several different charging cords and cleaned out the port. No help. I shortly remembered that I could charge the phone wirelessly and went on to charge the phone successfully and used the phone throughout the week. Last night I could no longer get my phone to charge wirelessly. Now, I can not even get the dead battery indicator to pop up.
Does anyone know what the issue might be as to why I can no longer charge my iPhone via lighting port or wireless?
No water damage.
Thanks in advance for any help here!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
It sounds like tristar ic is probably bad. It's what controls charging and data transfer. It can be caused by using an aftermarket charging cable that isn't MFI Certified. The cheap cables can cause voltage spikes and damage the tristar ic chip.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks,
Do you happen to know a good site to buy the replacement Tristar Chip?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Forrest Schultz 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 9
总计 27
