跳转到主内容
修复你的物品
维修的权力
商店
Can I use the Bluetooth WiFi card from a 2015 in this
So for some backstory if it helps I bought a 2013 MacBook Pro retina with no ssd and no WiFi card for 300, it also needs a few other parts but I was wondering if I can use the WiFi card from a 2015
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Yes the MacBook Pro Retina (2015) Airport/Bluetooth Board can be used in your system. The only difference between your MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board is the WiFi standards supported: 802.11n Vs 802.11ac.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board图片
产品
$79.99
MacBook Pro Retina (2015) Airport/Bluetooth Board图片
产品
$84.99
这个答案有帮助吗?
得分 0
评论:
Does that mean in theory it would be a better card
完成的
In practice it will offer better performance!
802.11: Wi-Fi standards and speeds explained
完成的
添加一条评论
添加你的答案
David bellows 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 35
