跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
connecting my iPhone to WiFi network
hello wish the all great weekend i want to ask why there is difference on wifi signal from iphone to another i have 3 iphones 8 plus two of them can not connect to the router while the other one can connect normally is this a problem on wifi antenna or what ???
please note : i tried to connect to the same router from a same distance the result is shown
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It sounds like you have a wifi router that is weak or are to far away. One of the phone is just receiving the signal better. I would say it the router.
这个答案有帮助吗?
得分 1
添加一条评论
I agree with @barriphone
You can go to your router and give it a try. If it doesn't work, then you can switch OFF your router for 5 minutes after that switch it ON and try.
I guess it will work.
这个答案有帮助吗?
得分 1
2条评论:
do you think it is a router problem ???
完成的
Yes. Go to another area and check the connection from a public wifi like a McDonald's or a library or a friends home.
完成的
添加一条评论
添加你的答案
tamer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
