跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
Ripped Ambient Light Sensor Face ID
Hello, I was working on another iPhone today and for the first time I ripped a flex cable. I ripped the cable connecting the ambient light sensor to the proximity and flood illumination. I was sure I have lost face ID but after booting up everything is normal. Should I just place the ripped sensor back in and call it a day? I have microsoldering skills but not great with flex cables and traces. I know that Apple disables the sensor when you replace the screen but I was just removing it to clean the glass underneath.
PS. I usually use heat to take the whole sensor assembly and plastic holder out but this time I didn’t need to transfer it over to a new screen so I tried to just pinch and remove the sensor. Noob mistake
Thanks for any help
I have included an image with a red line showing where the flex got torn.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The only option you have is solder the cable back together, put a new sensor assembly in it and lose face Id or take it to apple and have them repair it and program in a new sensor. They may try to swap out the phone if you go that route so back it up.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the reply. I have decided to just put the sensor back in without soldering it. I can't afford to lose face ID and having look at the ripped part its too close to the flood illuminator. I could damage that during soldering and then face ID would be dead. Everything works just not the automatic brightness control which I guess is better than having no face ID. Thanks for the comment though I appreciate it
完成的
添加一条评论
Just transfer over the original ambient light sensor to a new flex cable
这个答案有帮助吗?
得分 0
1条评论:
How would that work? The are one piece from the looks of it.
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 44
总计 4,291
