Xfinity remote won't turn on Yamaha receiver
I installed a Yamaha RX-V385 receiver, and paired the Xfinity X-15 remote to it. The only thing controlled is the volume. Why won’t it turn the receiver on?
I contacted Xfinity, and worked through the fix from their side. I hadn’t followed their program process far enough. By using another available code, I was able to accomplish my goal.
这个答案有帮助吗?
Howbout telling us the code that worked, thanks alot
Sounds like the programming code you used is not complete for your receiver. You may want to get a remote decoder Generic Universal Tv Ir Remote Control Decoder Tester Infrared Remote Control Testing
Then manually create your own remote controller program for your Xfinity remote. That is if you can program it manually, I haven’t done the X-15 remote so I’m not sure if that’s an option.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 30
总计 5,906
6条评论
Use code 32467 to fix the issue
由 LeRoy Smith 完成的
You are a genius LeRoy
由 biancohaku 完成的
I have the Yamaha Rex v575. Xfinity remote works all functions but it turns the unit on and then immediately turns it off? Why?
由 timtheattorney 完成的
Thank you Leroy
由 stevethirtysix 完成的
You are most welcome
由 LeRoy Smith 完成的
显示更多的1条评论
