跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
677 个问题 查看全部
iPhone 8 Plus Won't Turn on After Replacing Screen and Battery
Hey guys, recently I just replaced my iPhone screen and battery simultaneously. I put all together and it works great. However, I woke up the next morning to the phone completely dead. I thought it’d be a simple fix but my phone won’t reset, turn on, or anything. I’ve tried everything to figure out what the problem could be I disconnected the battery and put in the charger but the screen won’t turn on either so I took out the screen and installed my old broken screen with the charger and still nothing worked. I examined the connectors and everything on the phone but everything looked fine. I could really use some help here because I’m just in high school and can’t afford a new phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Did you try putting in the original battery? Did you try hooking it up to a computer and seeing if iTunes will recognize the phone?
完成的
Did you try a different charger? Have you used an aftermarket charging cable before?
完成的
I did try putting in the original battery and screen and arose with the same issue. I hooked it up to the computer and it refused to even recognize the phone. I tried an aftermarket cable then tried an original cable
完成的
添加一条评论
3个答案
Put back your old battery or buy a new battery and see if the phone boot up.
这个答案有帮助吗?
得分 0
1条评论:
I did put in the old battery however the LCD screen did not show any thing. I also put my old screen and nothing came up
完成的
添加一条评论
If Phone worked fine, then most likely battery and LCD is fine. Battery most likely had a charge in it and couldn’t charge back up due to pry damage to the Moffset(s) in the picture. If you are handy with a multimeter or have magnification… look around the circled area for missing/lifted or damaged components needed to charge your battery. Or use a Multimeter in “Diode Mode” to take the readings of the battery connector and see if they are correct or show “OL” (Open Line).
这个答案有帮助吗?
得分 0
1条评论:
I do not have those tools handy, I'm only in high school. I'm attempting to see if my AT&T has insurance on my phone to replace everything for me
完成的
添加一条评论
It sounds like a possibility that the tristar ic was damaged and it will stop charging and data transfer on the phone.
Update (06/19/2020)
Take it to a repair shop and have them test the tristar ic. It only takes a few seconds and most places will do it for free.
这个答案有帮助吗?
得分 0
1条评论:
Another thing is I did plug it in before and it charged fine. I woke up and the battery was dead, I have no idea what to do
完成的
添加一条评论
添加你的答案
Tyler p 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 1,352
