Device ran out of battery, doesn't turn on after 8 hours of charging
Sup!
I’ve let my switch run out of power, my clumsyass forgot to put it on charge overnight.
I’ve hooked it to charge, however after 8 hours (or even more) of charging it still doesn’t turn on. Not even the backlight appears. Holding and/or tapping the PowerButton didn’t do stuff.
What I did keep in mind is that I had an error message appear like 5 days ago while playing AnimalCrossing, the system restarted after that but that’s all. It still worked until i’ve let it run out of juice.
I had to repair it once because the left rail didn’t detect my joycon, but as much as i can recall nothing happened to the console before, during or after the repair. I’ve unplugged battery while repairing and only used plastic tweezers.
What could be the issue?
Do you remember the error message?
Might contain significant info.
由 Med_tech 完成的
I don't remember the error code, but it said "There was an error. The console has (or needs, not sure) to be restarted."
由 Yuka is Sleepy 完成的
I've had a few switches that would display a certain error code on bootup after showing the main menu.
These switches had the ability to boot up if the battery is charged enough (3.7V). But with a USB C ammeter no power was detected from the charger (the meter wouldn't turn on).
Turned out they were caused by the M92T charging chip.
由 Ben 完成的
@benjamen50 The thing is, the error randomly happened while I was playing a game, not on the main menu after bootup. I figured it could be the chip, but the chip is just fine.
