跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
239 个问题 查看全部
Is cell signal quality and the placement of the Network Antenna?
I have the 1st gen SE (i love the size) but i bought the new 2020 SE but i havent set it up yet. My worry is in regards to the placement of the cellular antenna compared to one another and even compared to an iphone 6s. I live in the woods and my 1st gen SE is the only phone in the house that gets LTE signal (in certain windows). I dont want to start the new one up and have my service auto switch just to have no signal. A family member has an iphone 6s that gets no signal at all with same service provider ( only verizon out here) so i was also curious where the antenna was on it as well, to see if the placement of the antenna even has anything to do with its lack of signal or not. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The 2020 SE is based on the iPhone 8 frame and antennas.
The original SE and the newer 2020 model use the same antenna design. The frame band is in fact four segments! If you look carefully you can see the breaks in the SE teardown (white gaps) and in the 2020 version the plastic is color matched! The top and bottom bands are the cellular antennas.
So from this perspective the only issue is the carriers cellular frequency bands available in your area and the ones the given phone supports. If you bought a Verizon iPhone you should be fine. But don’t you want something better than stand near a window??
So what to do??
Do you have cable internet? If you do you can now leverage it with many of the providers. Basically, you are using the phones WiFi connection to your WiFi router to then do a VoIP connection to your providers gateway to then connect to the person who you are calling or are calling you! Here’s the info on Verizon Wi-Fi Calling
I have WiFi calling with T-Mobile and its great! Even my Apple Watch which has a very limited antenna works quite well.
iPhone SE图片
指南
iPhone SE拆解
难度:
中等
iPhone SE 2020图片
指南
iPhone SE 2020 拆解
难度:
中等
这个答案有帮助吗?
得分 0
添加一条评论
Nope you should be fine if not better because of the new antenna technology!
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Kira Cochran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 811
