跳转到主内容
Can't find the internal hard drive
I spilled water on my keyboard, now the MacBook Pro A1150 turns on and can't find the HD, but it can boot from the external HD, it works perfectly.
Looking at the interconnection cable of the internal HD seems normal, any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First keep in mind this is a very old system! So anything you do might break something as the plastics get brittle!
From the sounds of it I would say the HD cable or its connections to the drive are in trouble. What is not very obvious is the drive has two connections on the PATA connector. One for the data ,and the other side for the power. Carefully lifting the drive up you should be able to see if power is even getting to the drive, use a DVM and measure the connection points. If you have power then you either have a bad data side connection of the cable or the drive its self got damaged.
这个答案有帮助吗?
得分 3
11条评论:
Hi Dan. What I find strange is that water damage may have caused the cable, visually the cable does not present any damage, and you can see that when I turn on the mac the HD is spinning.
完成的
I just removed the drive and put it on another mac it's working perfectly
完成的
Do you think it would be the case to remove the motherboard and give it a bath with isopropyl alcohol
完成的
I would still check both the logic board and cable for corrosion damage, If you don't see any I would replace the cable 15" MacBook Pro Hard Drive/BT/IR Cable, Apple P/N 922-7264
完成的
Hi Dan. I bought a new cable and replaced it, I still have the same problem, only boot, with external drive.
Today I took the motherboard out and cleaned it with isopropyl alcohol, I set it up again and the same problem, just from boot with an external drive, Ithe system doesn't recognize the internal drive?
I'm tried to find the diagram of the board of the Macbook pro Modelo 1150, to try to understand better this problem.
Here in Brazil the components for the 1150 are very cheap.
Any suggestion
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Jose Dias 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 112
