跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
88 个问题 查看全部
Left Joystick sends "down" data; 3D detecter "inversed"/broken?
Hi,
I have a problem with my Switch Pro Controller.
Left Joystick is sending the data “Down”.
But, I opened my controller as far as I could, and seems to be an issue on the “rotation detecters”, inversed/broken; or the motherboard is broken ?
Here’s my internal joystick.
I suppose the blue-green piece at right is for up/down motion
And on the bottom, this is for left/right motion
BUT
The piece at right seems to be unusable
AND
The strangest thing, it’s when there is “contact” on the bottom piece (which should control Left/Right motion, not Up/Down) that I have the “Down” data sent.
Look at the photo : it’s when I put this little circle piece that I have the issue.
When I fill it in, BOUM, it sends the Down data.
I don’t know what to do.
Change just the blue-green piece ?
I don’t understand how it’s possible to have this issue.
Maybe my motherboard or the connections are broken ?
Here is a picture :
Thanks for reading
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Tbh I always replace the entire joystick when this happens. The costs are pretty low. The only thing is that you need some experience with desoldering and soldering. And if you replace it, make sure you remove the old solder and clean it.
这个答案有帮助吗?
得分 0
2条评论:
Thanks koppie !
Oh boy, I'm afraid I'm not the best in this job, and seems to be quite difficult to desolder these contacts properly.
But I think I'll have to try, 'cause in the other case, the controller is still dead...
完成的
Yeah, you just need a copper wick/braid and remove all the solder. Make sure all contacts are solder free, otherwise you won’t get it out. Take your time here. When it’s freed, solder the new one in. I don’t think they sell the joystick in parts (anyway hard to find). You can always bring it in at a local repair shop to get it fixed. But I guess you will be proud when you will fix it by yourself :).
完成的
添加一条评论
添加你的答案
Riku76 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
