跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Mac Battery stays at 1% and turns off when unplugged
Left my Macbook on charge one night and the next morning unplugged it and it powered off straight away, I plugged it back in and noticed the charge percentage wasn’t moving. Tried the option key+press on the battery icon and it said ‘replace now’. I only got this laptop for Christmas 2018 (so I’ve had it for around a year and a half) so I don;t understand how the battery has gone already. I’ve attempted to do an SMC reset but the laptop doesn't turn back on when I press the power button unless I unplug and re-plug it, and there’s no difference to the battery. I updated the system (Catalina 10.15.5) and the only difference is when I press on the battery icon it says ‘battery is not charging’. Is there anything I can do right now other than take it to an Apple store?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
10条评论
Did you take out the AppleCare+ service contract? If you did Apple owes you a new battery!
完成的
Ah, I forgot to mention it! Sry Dan and Sophie!
完成的
@danj Unfortunately not, I think I only had a 1 year warranty so seems I'll have to pay for it to be fixed at the Apple shop they reopen. Any ideas on what could have damaged the battery so much? The only bad thing I can think of that I've done is leave it on charge too often.
完成的
It's not sitting on the charger its the cycles that kills most batteries. That gets into how you use the system, deep discharge and then recycling burns the cycles.
The second issue is the charger and now with USB-C the quality of the cable. Make sure the charger is certified by Apple or an Apple unit and use the Apple power USB-C cable.
完成的
@danj I'm still using the same cable I got with the Mac and one end of it looks to have turned slightly yellow so I'm thinking it could be one of the causes. Just been on my laptop for a while there and it shut off and restarted suddenly "because of a problem"
完成的
显示更多的5条评论
添加一条评论
8个答案
最有帮助的答案
Hi!
I don’t want to scare you, but yeah looks like your battery is dead. Not sure if you can test with another charger? At the Apple Store they can. You can try to fix it for yourself, but this will be not easy.
Guide: 2017年款带功能键 的13寸 MacBook Pro 电池更换
So you can decide for yourself to fix it or let it be fixed. And yeah, I agree, this shouldn’t happen withing 2 years… But also depends on how you used it.. Perhaps someone else know if this is a common issue or that something else is broken which is causing it (I don’t have a lot of experience with this Macbook). But so far I can tell now, it looks like your battery is out of the game..
这个答案有帮助吗?
得分 3
2条评论:
Yeah I was kinda afraid of that :/. Thank you anyway though!
完成的
No worries! But Dan is right, If you took the AppleCare+ contract, Apple owes you a new battery.
完成的
添加一条评论
Hi, i'm facing a very similar problem, except that i'm using a 2016 13” mac book pro and started using in the latter part of 2017 only. The end of the USB C charging cable that i always plug to the side of the mac book has turned slightly yellow as well. And i've been getting this problem ftom somewhere in the 1st week of june as well. And resetting SMC didnt help.
这个答案有帮助吗?
得分 1
5条评论:
Could you solve the problem?
完成的
The best thing you can do is to install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
You also want a better means to monitor your chargers power using a USB-C power meter like Satechi USB-C Power Meter Tester
Depending on its age you may in fact need a new battery. You could have a bad charger and/or cable as well. Make sure you use the correct cable as many 3rd party cables are not fully wired or have the needed wire gage.
完成的
Yeahhh I ended up having to get a new battery, the Apple guy said it wasn't anything I did, it was just a battery failure, which shouldn't happen within 2 years. Turns out the laptop was bought from John Lewis and I have a 2 year warranty on it, but it doesn't cover the battery for some reason. I'd definitely get your battery checked out.
完成的
I also asked about the charger, because my lead was going yellow at the ends too, and he said I shouldn't have to replace it, it's just from overuse I think.
完成的
Was your mac super slow when it was stuck on 1% battery?
完成的
添加一条评论
Same problem for me. And I have seen many macbook pro users say they are facing the same issue. Some users even have the same problem after they purchased a new battery. I think that’s a software problem but Apple haven’t have any reponse yet.
这个答案有帮助吗?
得分 1
3条评论:
完成的
Yeees, I’ve same problem and it comes back super slow.
完成的
Same problem here. My mac is stuck on 1% battery and now is extremely slow.
完成的
添加一条评论
I am having the same problem with 13” Mac Book Pro. I purchased a new power adapter and USB-C cable from apple ($125 together)… problem still persists. I turned off battery management … did not help. When I put my Mac into sleep cycle it will eventually charge… it usually takes 10 to 15 hours to charge this way but eventually it is recharged. Right now … I’m at 100%… I unplugged the power adapter… but it thinks that the power adapter is plugged in and charging. I think its a Catalina problem.
这个答案有帮助吗?
得分 0
2条评论:
@sirbman - If you really feel this is a Catalina issue you should visit an Apple Store to get it verified.
Sadly, I think you have a hardware level issue within your logic board. The Apple Store can verify if thats the case as well.
完成的
I just upgraded to Catalina. My battery was fine and fully charged when I started the install, but by the time it was done the battery read 1% and it won't charge. If you look at system information it says there is 0 charge remaining, but it also says it's fully charged so it won't let it charge. I have tried resetting the SMC but as mentioned above the only way I can get it to come back on is to unplug and replug the USB-C.
Charge Information:
Charge Remaining (mAh): 0
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 6389
Health Information:
Cycle Count: 109
Condition: Service Recommended
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12753
完成的
添加一条评论
Hi,
I’m struggling with the same situation. As far as I know, the ultimate solution would be the battery replacement, but frankly, I would like to avoid that. My battery has only 316 cycles and is 1181 days old, and still on 82.5% of design capacity.
I’ve tried multiple things like SMC reset, SW updates, etc., but still cannot charge (with the original Apple USB-C charger).
Can you see any other option than battery replacement?
Thanks a lot!
Jiri
这个答案有帮助吗?
得分 0
7条评论:
Did u get it fixed and how if u did
完成的
Same here after updating macOS.
完成的
The fix has been done by battery replacement.
完成的
@Jiri Fiala Your battery seems good.
完成的
@whatisup Unfortunately, nothing else worked for me. The replacement was the only solution...
完成的
显示更多的2条评论
添加一条评论
I have the same issue now (not charging with always 1% power) after updating the macOS to 10.15.6. I guess that the reason is the feature ‘battery health management’ that was introduced in 10.15.5.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
I have the same problem. I can’t find the solution.
Does anyone find the solution yet?
这个答案有帮助吗?
得分 0
2条评论:
Hey, I think it’ll definitely be your battery. The only fix for mine was to get it replaced sadly, which costs a few.
完成的
Hey, the only fix that worked for me was the battery replacement...
完成的
添加一条评论
You can bring it to a repair store to check what’s wrong either the battery or charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sophie 将永远感激不已
浏览统计数据:
过去 24 小时: 20
过去 7 天: 88
过去 30 天: 398
总计 36,767
