跳转到主内容
修复你的物品
维修的权力
商店
Vizio 42" LED TV released in September 2012.
36 个问题 查看全部
Why does my Vizio TV intermittently have sound but no picture?
I have a Vizio E55-E2. The screen will go off but the sound is still on. I can get the screen to come back on by holding down the mute button for 3-5 seconds and then pressing the menu button. The screen will come back on for minutes/hours and then eventually it will go off again. It is not a consistent amount of time.
I opened the back of the TV to look at the boards and the pictures of each board are provided.
any help would be appreciated!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
@tmat85 once the picture turns black and you still have sound, shine a flashlight at an angle against the screen. See if you can still make out shapes, silhouettes etc. This could be a failing backlight issue, as well as a bad power/main board. You would need to check the voltage from your power board to the backlight LED when the screen is lit and then against when the screen turns off. if you see a big difference it is most likely the power board. Again, you will need to check the voltages on BKLight on from the main board before and during failure to light up. Let us know what you find out.
这个答案有帮助吗?
得分 0
评论:
Thanks! I will update after I test. And to answer your question, I am able to see shapes and shadows with a flashlight.
完成的
添加一条评论
添加你的答案
Trevor Mathews 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 50
